mwood1985
I recently swapped to a hydro bellhousing and pedals. I pulled my column out get the pedals in and the next time I drove it at night I noticed im having major voltage issues. the headlights flicker and cutoff when I go over bumps and seems to happen when I hit the brake pedal as well. I made sure I didn't hit any wires during the reinstall but im thining I possibly damaged one and its grounding. theres no problem with the headlight switch off but it rears its ugly head when the switch is on. if the truck sits still it dosent short out. any ideas on where to start looking? battery and alternator both tested good ive got 14.6 at the alternator roughly 13.5-14 at the fuse panel.
