nomad350z
Registered Member
I've got an 83 Blazer, and its been giving me some electrical issues over the past few months. Where to begin....
When I first started on it, everything seemed to work well. It needed a transmission, so I swapped the worn out TH350 for a 700R4 for the obvious overdrive. Had to buy a new tranny output shaft, and swapped in a Caprice 700R4 with the 4x4 output shaft.
Shortly after the swap, I was romping the truck and smashed the windshield, and had some minor firewall damage (tree limb through the grill, bent the firewall a little near the wiper motor). Since then, the radio doesn't work and my windshield wipers won't work (probably because the linkage is bent). The radio is shorted somewhere, I know because the second I change the fuse it blows a new one, you can actually watch the spark the instant the fuse makes contact, so Its currently without a fuse. Around this time, I noticed the voltage getting low, so I figured the voltage regulator was bad, and I swapped in a new one.
On a trip, I would notice the voltage would swap, between ~11V and ~16V. No matter the load (lights on, AC on, etc), it would go back and forth.
Now, during the day under no load (no lights, no AC, nothing) it will stay constant at 13 V on the dash gauge. At night, with lights on, the voltage will drop dramatically, and if driven enough the truck won't start again when turned off. I've been using a 2 amp charger and night to keep it up and functioning.
I haven't tested the voltage regulator yet, seeing as I don't have a multimeter and haven't had time to check the magnetism on the alternator itself, but is it likely I've gone through two alternators in less than a year? Granted it was a rebuilt Autozone POS, but still.....
My biggest concern is that there is a short somewhere near the firewall, and its draining my battery. I don't want to burn the truck to the ground either, so I'm in need of some advice.
How can I check for a short with the radio? Should I change the alternator? The truck runs fine under no load, so I'm curious about the voltage regulator being bad....
Please Help!
Please Help!
