I've got a need for some electrical plugs. There are 3 on a truck and I seem to be missing 2. They are not needed unless you are smoging the vehicle, and even then you may not need them. Locations: top of carbon canister, smog pump valve, and back of intake manifold near the EGR (tube goes to EGR). I think this stuff was CCC equipment only. The plugs look like #5, each having two male prongs, but I'm unsure if the LMC ones are the actual ones. Anyone got some kicking around? Haven't had any luck with the junkyard lately.
