FYI, got a response back from Antigravity batteries:
"Thank you for reaching out to us.
As long as your charging voltage is in the 13.2 to 14.6 V range, you shouldn't see any issues. Our car batteries are designed to handle typical engine bay temperatures, and they come with protections from over-discharge, over-voltage, overheating/thermal runaway, and short circuit. Some newer cars with smart charging systems can be problematic for our batteries, but they generally work great in older cars. You just want to avoid installing it right next to a big source of heat, like the engine manifold, for example. If the car is modified and the engine bay temps are slightly higher than normal, some heat resistant wrapping should suffice, but if the engine bay temps are significantly higher than stock, I recommend relocating the battery to be on the safe side.
I have an older car as well (1991 Prelude Si) and I'm using our ATX20-HD motorcycle battery. It's been bulletproof for the past six years. If you're looking for a smaller battery as well, an ATX30-HD would be great for your car as long as you don't have any power thirsty accessories.
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atx30-hd/
Here is a video with lots of info on our batteries and lithium in general.
https://youtu.be/R_rw_qstFdE?si=qZ1uiGgG4zWMxe3R
Have a great day, and please let me know if you have any additional questions."
FWIW I see "Lithium Ion" on their batteries (and mention in the video) however they clarify that all are LifePo4.
Relatively pricey, but based on the cost of other lithiums advertised as automotive starters, it's not outrageous. More than I'm willing to pay for the cost/benefit in my case, but for a daily driver, they could be a good option. Another thing I remembered but hadn't thought to put down, corrosion should be nil with these batteries.
If a manufacturer is going to allow reps to state that the batteries will work as a drop in, I'm inclined to test the tiny one in the truck just for the heck of it, with the alternator.
Still concerned about the underhood heat and starter draw, so will have to test to get those numbers when I get the chance.
