So I think I have an understanding about wire size and length but I would like to get more input.
I bought an F150 fuse box and plan to use it for under hood power distribution. Not all the wires are as large as I want, and finding the correct terminals to redo these wires is impossible. If I want, lets say, a 10ga wire to run to my lights, but my only fuse or relay option has a 14ga lead, would it be bad to have 6 inches of 14ga wire in there? My understanding is that it will be fine since it is so short, although I should fuse the circuit for the 14ga wire. Am I right?
Some say it will bottleneck the current, others say it will be fine because there is insignificant voltage drop over a wire of that length (think fusible link or fuse element) What do you think?
I have also compiled a series of charts of wire size to recommended current, fuse size, max current etc if anyone wants to see it. (of course not one chart reads the same, but all are ballpark close in numbers)
