vandelay industries
Eliminate EGR? Your thoughts?
i don't have anything against EGR and what it does; i mainly wanted to clear up some space and clutter.
What are your thoughts on eliminating the EGR valve? If, in fact, it really does help the engine last longer (supposedly) then i don't have a problem leaving it. It's a stock transportation engine so i'm not necessarily wanting to remove it for any performance benefit.
Again, it's mainly to clear up some space---this is on a 4.3 v-6 with the factory "hi-rise" manifold. In this case the EGR valve is right in front of the carb and slightly below it. It's basically blocking the passenger side idle mixture screw.
