4xcrazy
3/4 ton status
Well, here's the deal, it has literally been so long since i have messed with a carb'd motor,,,,maybe i am forgetting something,,,
Just got in from messin with this thing again, here's what i did...
retarded the timing back down, but the further i went, the more vacuum i lost, by the time i got it back down to stock area of timing,about 8 degrees (no vacuum advance) the vacuum gauge was reading like 10in/hg, tried adjusting the carb alittle here and there, pulled off a vacuum cap to create a vacuum leak,,,nothing really did anything significant.
so, now, the best vacuum i can get out of this,,,if i am reading this correctly is nearly 20 degrees advanced (no vacuum advance hooked up) and with a fulltime vac port unplugged,,got it at about 17in/hg.
i plugged the vacuum leak/port and the vac dropped to 10in/hg again...
the whole time, the vacuum gauge does not bounce more than MAYBE 1in/hg,,IF that,
it will run smooth, nice throttle response for the settings, but still smells abit rich from the pipes. ON EITHER WAY.
maybe i should just convert to TBI or something
I am extremely frustrated, but suprisingly not pissed, maybe just not the right setup for this application or something,,,MAYBE i do need the A.I.R. injection on this thing..
ONE OTHER THING,,how far back from the header collectors is usually optimal for the proper heating of the cats? Mine are approximately 3.5, MAYBE 4feet back from the collector
(i didn't do this)
and again, i thank you all for any tips/tricks/advice on this thing
(i didn't do this)
