Ok, I had a shop replace main crankshaft bearings in my K5. It's a 350 with rv cam, stock iron heads approx. 135k miles since rebuild in 2010. Bearings were showing copper some down to the metal but crank was fine. First, they put the rear main seal backwards, leaking. Then after the shop did the rear main for 2nd time, the tech said it was ready. She drove it around to the front of shop but sounded like a rocks bouncing in a can. Top end noise, like valve train. I asked why does it sound like a diesel. She said thats normal, would go away after 1000 miles. I couldn't believe what I was hearing. I said doesn't seem right, you sure it's safe to drive? It was at zero oil pressure. Shop says it had pressure when they first started it but oil pump must have lost prime the next day. Does that even make sense? Seems more like the rod came loose to the oil pump or not seated right to the dizzy. Then they replaced all the bearings, rod too. But said now a slight miss and says it needs lifters? I feel like this shop is not being straight with me. Is simply replacing all bearings and lifters going to fix the engine after running without oil pressure? What should I do?
