badmix
Was helping a buddy put in some cam bearings in a 86 chevy 350 block. The box has them in what looks like the order they need to go into the block. Is this correct? I know the end bearing has 2 holes. But the other bearings have diff. part number on them. does this matter. And are the bearings in the box a "match" set. We also got one bearing that was way too small for the hole so we need to take it back, but was told that you cant jus replace one bearing that they are matched set in the box. Jus trying to get some specific info. This is a first time engine builder/build up.
