tiger9297
Just built a 388 stroker for my '90 K5. 9.5:1 compression, XE262 cam, Vortec heads, and Howell MPFI. We have tried everything, but it just won't run right. It's doesn't idle smoothly and when you crank it you have to give it some gas to make it run. Running down the road it seems to smooth out and do ok. Timing is currently set at 9*. Everything on the truck is brand new except the starter and the alternator. The only thing that seems to make a change is unplugging the MAP sensor. Sometimes it will crank right up and idle smoothly when it's unplugged. However, after it warms up it won't idle at all with the MAP sensor unplugged. Does anyone have a clue what could be wrong with this thing? Oh yea, Howell burned a new chip for it.
