CobraEatr
Registered Member
Now before some of you try to kill me for replacing my TPI with a carb setup, please know that I've thought about this for some time now and I really want to do this. I know the disadvantages, but I want a carb. Replacing all the sensors has nickel-and-dimed me to death. I'm ready to tune my car in the garage with a screwdriver instead of having to use a laptop. I've posted a trade in the 'For Sale' section of this board and I think I've found someone to trade me their carb setup for my TPI setup.
My Blazer is a 1984, with a rebuilt 350 V8 from a 1989 Blazer. The TPI is from a 1985 Z28 Camaro. I was told by the previous owner that if I did change back to carb then I would have to use an electric fuel pump instead of a mechanical one because there isn't a place on the block for the mechanical pump due to the block being an '89. I have no idea what he's talking about.
Now, here's my question. What exactly will I need to get from someone in order to make my Blazer run. I'm just a shadetree mechanic that has installed bolt-ons but have never gone internal into the motor. Below is a list of items that I think I need, but please add anything and everything that I'm missing.
1. Lower Intake Manifold
2. Carbuerator
3. Distributor (can I use mine ??)
4. Fuel Pump
5. New Throttle Cable (?)
Am I missing anything else?
After posting pics of my engine bay, I was told that I have center-bolt heads. Then I was told that having those would eliminate me using any stock carb setup. What's the difference between my heads (center-bolt) and the stock ones?
I've already taken off my current upper and lower intakes, distributor, throttle body, and fuel rails. All that's left for me to remove is the wiring harnesses, computer, and the fuel pump (which is located under the hood).
Thanks for any info that may help me with this.
2. Carbuerator
4. Fuel Pump
