Matt J.
To make a long story short -
Bought a 1988 K2500LD Pick Up. Truck runs and drives well. Previous owner inherited the truck from his dad who passed away a couple years ago so he knows nothing about previous work done other than a 350 block was installed using the components from the old 305. No build sheet or reciepts to clarify.
This seems to hold some truth as most of the components look older and the block itself looks clean and new. I'm trying determine if this block is indeed a 350 so I can double check to see if they did everything correctly such as 350 injectors, 350 Knock sensor, chip etc...
Front passenger side of block shows numbers V1211CLS. Does this look like a crate engine ID number? I didn't see this number on the Mortec website under SBC's. It doesn't look like I can easily access the numbers on the back of the motor near the bellhousing.
What say the brotherhood?
Thanks for your help, Matt
