CODE 44 - oxygen sensor out of range - lean condition
youve got too much air, meaning not enough fuel. what would i do...
1. new fuel filter - start cheap, this is inexpensive, and easy, and often fixes a fuel delivery problem on an old vehicle. did you run the tank very close to empty any time recently? gasoline is very dirty as a fuel, and leaves lots of deposites in the bottom of the tank. run it near empty, and you pick all that crap up. can clog a filter up quick.
2. fuel pressure regulator - if this has failed, youre not retaining enough fuel pressure to supply enough fuel to the engine to keep it running.
3. new fuel pump - not nearly as easy, may require dropping the tank. not sure how to test the pump before removing it to save you time and energy.
4. i dunno... fuel injectors maybe?
basically the fuel is hitting a restriction somewhere between the tank and the cylinders. the filter, pump, injectors, pressure regulator. all play a part in this system.
EDIT - OH and while its not normal for this to make the engine lope and stall, it could be a faulty O2 sensor, that is telling the engine its lean, and the engine is turning the fuel wayyyy up too rich to compensate for the false reading, and because its too rich, it stalls out. does the exhaust smell heavily of unburned fuel???
