buffblazer
ok so i have talked about this before but nobody really posted on it.
I have an 86 k5 with a 350, bored .30 flat top pistons, stock heads edlebrock performer intake. holley truck advenger 650. headers, no emissions at all.
now the truck runs great, if you ease into the throttle in any gear it will run as smooth as a new truck. but if you put it to the floor it will misfire and pop through the exhaust around 2500-3200 rpm and then clear itself out.
Im running an SM465. it will not do this in first gear, just second and third. and the weird thing is, it will not do it on the dyno,
so what im trying to say is. on a dyno sitting still, it runs like a champ. but on the open road it misfires.
never did this before the shop put the holley on it so i was assuming that was the root of the problem. on the dyno it runs a perfect 14.7 air/fuel.
now the misfire is the type that you would get when the engine was cold. i have a 205 thermostat in it and yes it is colorado but the other day it was 50 out and it still did it.
the shop is dumbstuck and im out of ideas. what says CK5?
