Hey all,
Weird little situation I have here. I did some work to my truck yesterday, including installing an H pipe into my dual setup. I also found another ignition power lead for my electric choke, so I finally got that working right.
After I did the work on the truck, it was missing under load, like I had a plug wire arcing out. I have had issue with plug wires arcing before, but resolved it by installing a different design header w high temp wrap, and moving to all 90* boots; since then my truck has been perfect.
I noticed my 12v. choke lead wasn't working. I have a 91 truck running a carbed 350, so I walked around looking for 12v switched ignition wires and realized the injectors have switched ignition leads running to them. Since all my EFI stuff is disconnected and set aside, I spliced into one of these leads to use for my choke. Could this be an issue? Volt meter gave me 11.4 v when I measured it.
Otherwise, would I need to make any A/F adjustments on the carb after adding an H-pipe?
Thanks for any suggestions.
It worked fine before you said so unhook it and see what it does.. I had a 350 carbed do the exact same under load missing. ended up being the switched lead going to the coil was tapped into to run the electric fuel pump the PO put in. Robbed power from each other when under load
