OK, first of all, not my truck. Second, its been handled, so no pressure.
But I just wanted to ask.......
Friend of mine has a shop. I hang around there a lot, and know everybody there.
His main mechanic has been building some kind of small truck in his spare time. The body is an S10, not sure of the year. Probably 2006 or so.
Had a six cylinder in it, I think.
2WD.
He built a 350 from the block up to go in it. Last Saturday, he was going to drop it in. I happened to be there doing some computer work on their system.
I had some slack time waiting for a backup to finish, so I wandered out to see how it was going. He had run the lift that it was on up, and was looking up under it with a stunned look on his face. One interesting thing I noticed, it was a two post lift with the arms, and he had had to tie the truck to the front arms to keep it from tipping over backwards with no engine.
It seems he had gotten to the point where he was going to change the engine mounts, and had hit a snag.
Each mount was held on by 4 bolts. He hit the first one with his impact, and it broke loose and spun. But, did not come out.
He tried the next one, same thing.
By looking up through a small space next to the suspension arm, he discovered that they had nuts on the back sides inside the frame.
We raised the truck up and down, looking for some way to get to those nuts. There is no way. To even touch them would require taking the front suspension off, springs and all.
Everything there is in good shape, and he did not want to go to that much trouble right then. I suspect he may have to replace the springs later due to the difference in weight, but right then he wanted to get the engine in.
After I left, he finally cut the bolts off, and found some the same size. Cut the heads off them, and welded them in as studs.
When I was there yesterday working on my filter problem, he had the engine in place.
My question is: Was that necessary, or was there some way we just did not see to get a wrench on those nuts?
I know car companies do stupid stuff, just consider what is involved in changing heater cores in many cars and trucks.
But did they really fix it so you have to take the front suspension out to replace the motor mounts?
My comment as I was leaving, was that I guess they figured by the time those enclosed mounts wore out, the front suspension would be worn out too, so might as well do both.
Or, more likely, they wanted you to buy a new truck.
As they say, Asking for a friend.....
2WD.
