blaznaro
Registered Member
Im installing a 1996 -2005 vortec v8 350 GM Goodwrench crate into a 1989 Blazer Full Size 4x4. Thus far the engine swap went smoothly until I tried to pin the motor mounts and secure the engine block. I first went to replace the engine mount bushings and clam shells with new aftermarket oem. After inspecting the part and saw that it was made in china and a POS !!! , I decided to go with new energy suspension bushings instead. The original clam shells have been reused with the new bushings and loosely installed on the frame. After several tries to seat the engine and slide the center bolt in... with no luck ??? we decided to unmount the clam shells and secure the center pins first. After several attempts to secure the three mounting bolts which are used to mount the clam shell bushing to the frame rail engine mounting bracket we found that if we bolted the driver side down we were off by an inch on the passenger side. So we tried to bolt down the passenger side first and then the driver side. Same outcome, Off by an inch or so in order for the mounting holes and brackets to line up.
The engine blocks should mount the same .... the original clam shells have been reused with new bushings and the engine mounts that bolt to the engine block and allow the center bolt to be secured to the bushing are off of a 1996 chevy truck that had a vortec v8 in it. I wld have used the original brackets but my son scrapped the old engine before i could unbolt them.
Just wondering what the problem might be.... the brackets looked the same as the originals but they might be slightly different. Or could it be that the bushings have been manufactured improperly.... doubt it with energy suspension.... in any case im stumped....
I did contact a chevy dealer locally and was informed that the engine mounting brackets and the spacer plates that go behind them when mounted on the engine block... are unavailable...discontinued !
