i have a ton of engine/tranny movement in my jimmy.top of shifter moves 6-8" side to side when under load .has new mounts on the engine and tranny.i have a 454/sm465.
im thinking of chaining the engine down like we used to do with drag cars.put chain on both sides of the engine since the movement is worse when in reverse. any body done this? good or bad effects?what did you use,chain,cable straps? thanks
from the junk yard. It was used to secure the cab to the frame and about 8" long. Bolted it to a spare hole in block on drivers' side to frame and corrected the problem for around 5.00.
