Recently I rebuilt the carb and replaced the oil in the 78 350 K5. The engine had not run in years. When I started it up it put out constent white smoke. Also had high rpm.
I checked my oil level and it is over 1-1.5 inches over full. I've never had it that full before. I should have checked it before starting.
Anyways I'm wondering if the white smoke was from the high oil level. Next thing when I have a chance will be to remove some oil.
