So now that im having a lot of issues with my tbi motor electrical wise im really determined to find a new route to go. ive narrowed it down to either 6.0 ls or a p400 6.5 diesel. I'm mainly interested in what you guys think will be easier/better to swap in the certain areas. Truck will be used for long distance travel both on road and long trails. Fuel economy is what is pushing me towards the diesel side. Also less electrical components. But when I do the swap I'm looking to add cruise control and ac along with a couple other modern amenities depending on which engine I choose. I know the 6.0 if I choose dbw will be fairly simply to add cruise control, but I'm not sure how the diesels work with that. Ac shouldn't be hard to figure out on either side.
Also which ever way I choose will be brand new. No used engines. That being said getting all the accessories will be a chore. How difficult will it be tracking down brackets for either engine? Keep in mind I will want serp belt set up for the 6.5 if I go that route.
Another thing drivability wise. I've never driven a 6.2/6.5 but I do have a 09 2500hd with a 6.0 that I drive every day for work. How do the 2 compare with rpm ranges and shifting and such. Keep in mind this will be backed by nv4500. I know the diesels have a lower red line but is normal driving much different between the 2? I know my 2500 is thirsty especially once I have all my tools and ladders on it. 10mpg Even when I had it empty and I did a little trail ride last weekend was around 8mpg over 150 or so miles. Are the diesels that much better like I've heard?
