aknight_sa
good day guys,
i am having a problem with my 454 engine, the story goes like this:
i was having some problems with starting the engine some time ago, and the problem was from the coil of the HEI, after replacing it and starting the engine, it started but a little rough...
i gave it some time to warm up then i wanted to drive it a bit.. but it was still rough.. then i gave the engine a big throttle and a big bang happened which caused lots of black smoke to come out and then the engine cleared out.. i started to drive it a bit.. then i noticed that some times when i give it some gas i hear the sound similar to metal hitting each other...i dont know what the sound is from... but the engine does run normally except for the sound that comes and goes all the time.. i am sure its not from the crank...
does anyone know whats its from..??
