engine rebuild
Summit has a few depending on what you need for the rebuild. Some run 2-250 while others are in the 5-600 range with pistons and crank. I am currently looking for the same info for a 454 tbi rebuild I am starting. I am only waiting to find out how bad and which bearing spun in the engine. Once I do tear down I can then set the budget.
yea summit. If you are gonna rebuild it yourself, you can find kits on there that are very affordable.
