V8power
Registered Member
Hey, my pickup coil went out recently and my 85 blazer wouldnt start. I replaced the module in the distributor and coil then eventually pickup coil which fixed it. It now starts up within 2 seconds of turning it over. The only problem Ive got now is it sounds like a belt is loose when i give it more then idle throttle (it makes a squealing noise) but I tightened the belt and its still there. Also, it sounds like its not running very well, and if I put it in drive and give it a decent amount of throttle it will almost die. Does anyone know what this could be? My dad (a mechanic) said the choke could be stuck on. Anyone had this happen to them before? Any input would be great.
Also, I timed it after I put the distributor back in.
