vandelay industries
Next Crisis:
As you may know, i've swapped a 4.3 in where a 305 was. Anyways i can get it to start up pretty easy, but it immediately stalls out---like after only a split second to 1 second.
i'm leaning/hoping maybe the timing is too retarded; When i was messing around with the distributor last weekend, constantly taking the cap off and on and doing tests (see other post entitled "no spark, no tach signal") the distributor did move---apparently wasn't tightened down well. Maybe not enough to retard it bad, then again maybe.
i don't think it's fuel or the choke---it's pretty warm here right now. Plus, i experimented with the choke. Opening it all the way, opening it a little right after startup, keeping it closed. But all still the same results.
Thoughts?
Thoughts?
Hooked it up and it ran great.
