mattrains
MRAINS
My k5 blazer currently has a 454 big block and turbo 400 combo. I am trying to swap in a small block motor. My question is can I use the same frame perches that are in there or do I need to find small block frame perches for my motor. I am Not sure if they are different or the same?
I am referring to the peace the motor mount bolts to that connects the engine motor mount to the frame. Also do I need to swap my cross member from a big block crossmember to a small block crossmember?
