Definitely more involved than swapping in another 350. Motor mounts, oil pan clearance, wiring, trans mission crossmember (depending on the trans), radiator hoses etc.
That being said it’s not hard if you take your time and do your research. There is a ton of info out there. Literal books have been written in swapping an LS into anything.
