goathearder
Hey Guys,
I have a ticking noise coming from my 350 that is driving me crazy. I ONLY hear the ticking during acceleration or when the motor is under load. I.E. if I put it in park and rev the engine there is no noise, you also don't hear it at idle.
It also doesn't matter if the car is warmed up or not, it is still there. The ticking also becomes faster the higher the RPM is.
I totally though it was an header to block leak because of the location it is coming from so I added some soft aluminum header gaskets and it still leaks. I also can't "feel" any leaks around the header so I am starting to think it might be lifters.
Is there anything it could be besides lifters? Is there any way to diagnose bad lifters?
If I replace the lifters do I have to replace the Cam and pushrods at the same time?
Thanks,
John
Thanks,
John
