Gotta bit of a problem, I notice a bit of a vibration at around 3100-3200 rpms. I just rebuilt this engine with all new parts and had it balanced at the local machine shop. I took it to them and they said a missfire could cause this problem to. Me and my buddies think the rotating assembly is out of balance but is it possible a missfire would cause that.
I have a set of comp cams lifters that wont stay in adjustment and one, maby 2 are really noisy. I tried 1/2 and 3/4 past zero lash and eventually they start making noise again. Could them crappy lifters be causing uneven cylinder pressures and the vibration.
The whole rotating assembly was balanced with the dampner and flywheel. Its usually below 0 here and I dont have much motivation to pull the motor out again, but I could handle the top end work.
Its weird you think youde be able to notice it at lower rpms but not till it hits about 3200 then its instantly there, maby im wrong..
What do u guys think???
. I think I have a bit of a head gasket problem so im just gunna pull the heads and replace the gaskets and lifters. Hopefully its just a high rpm miss(or 2), but im not gunna hold my breath. Ill pull the motor out in the spring time if it still vibrates.
