ENGINES...ENGINES....ENGINES....(and a couple Trannys)!!
Greg72
@MIGHTASWELLK5
Staff member
Super Moderator
Austin, TX
The latest list as of 2008.02.04
(SOLD!) 454BBC - Gen V Block. Project motor. Needs machining, rods, pistons. Crank looks salvageable.
Cylinder Heads were recently rebuilt by 4X4HIGH....ready to bolt on and go!
Casting Numbers: 10114156
Description: 91-up...oval...OPEN...Gen.V & VI 454, 118cc chamber - $300.00 for the whole package
TH400 (2WD) - Looks like a passenger car version (non-HD) but still worth some $$$ as a good rebuildable core. - $300.00 / offer
(SALE PENDING ITEMS):
____________________________________________________
TH350 (4WD) - Also from Stomper. Not going to need this one much longer....ran an HD cooler on it, and it never ran hot. Everyone said it was crazy to run a TH350 behind a big block, but it's been working like a champ since I bought the truck originally in 2001. Go figure.
NP205 - Chevy side drop (should be obvious). From Stomper also....won't need this one once the winter swap is completed.
:usaflag:
Greg, someones been into that engine before since the rods are numbered and it also has a fel-pro oil pan gasket. Definately a 4 bolt block with a cast crank. You could always pull a rod cap and main cap to see what size bearings are in it. I'll bet it's been bored at least once.
the 205. Will it bolt up to a 700r4, with the right adapter?
With a short output shaft (advance adapters) or a spacer it will bolt right up to a turbo 350 205.
TTT - Let's move these final items... I'd like the space & need the cash. :deal:
:usaflag:
