Erratic shifting problems, '95 Sonoma, 4L60e
big94gmc
No VA.
Here's the skinny.... The only thing standing in my way before I will begin my SAS is the tranny/shifting issues (it's 'in my way' because that's my choice - maintenance before modification, always). My knowledge of auto transmissions is just a hair above zero.
So, I'll try to describe this as best I can....
I bought this '95 non-Zr2 Sonoma a year ago....139,xxx miles on it when I got it, and I'm going to say the owner was an unreliable source of honest/factual information about the truck. I test drove the truck before handing over the money for it, and I could tell something wasn't quite right, but for the price, I couldn't pass up on the initial cost. So, back on topic....
It has always felt like, for lack of a better expression, it was tied to a tree - by the, I mean, we all know our trucks aren't the quickest things on the road, but this is ridiculous. I jokingly call the truck The Noisemaker, 'cause for all the sound coming out of the exhaust, it doesn't go anywhere. In order for the truck to smoothly run through the gears and get up to highway speed, I have to (more or less) feather the gas pedal. If I pin the pedal to the floor (let's call this 100%), it will run though First gear correctly, but then it will stay in Second until I let off the pedal. 7 times out of 10, when I do this, it will be stuck in Second gear (what I believe is called Limp Mode - I have Second only). The only way to get out of that is to shut the truck off for a minute or so, then restart, and it will shift again. (And, Yes, there has been a couple times when I've shut the truck down while driving down the road, and coasted until I though enough time had passed to restart.) If I gradually build up on the accelerator (I'll call this 50-75%), then I almost always experience that it will hold Second gear until about 66-68 mph, and then rapidly fall to Third and Fourth. Passing people while at highway speed is a joke....obviously, it will downshift into Second, but then holds it until I either let off the accelerator, or I hit ~70mph, followed by the rapid Third and Fourth shifts.
I had a friend tell me he thinks it's a harness issue. I don't know, could it be? Could some of this be TC related? Could some of this be valvebody related? I need to figure out what I need to do (to purchase, and/or pay attention to) to get this truck operating normally so that I may begin modifying it.
I do not want to fall into a crap-sandwich where I throw a ton a money at it, only to find out I wasn't doing the right thing.
Can anyone help me/guide me? Thanks alot, fellas
have you checked it for any codes?
Maybe a govenor problem? I think these are also controlled by the throttle position sensor feedback to the drivetrain contol module. What does the fluid look like, if things are slipping it'll burn it in a hurry.
sounds like the tranny is shot to me.usually will start by slipping.then you will start losing gears.rapid drop to 3 and 4 sounds like death to that tranny.at 130,000 has it ever been serviced?drop the trans pan and see what kind of metal may be in the bottom of the pan.thats the easies way to tell if something is broke in there.if the fluids and filter never been changed it may not be getting enough fluid through it and burn it up.fluid should be light pink if it is still good.smell it and see if it smells burnt.let us know what you find.
Checked for codes, no. I thought 'codes' were only present if a light were on, and there are no lights showing.
Also, I haven't dropped the pan yet, since I'm still driving it.... I had wanted to get everything I'd need for it before pulling it.
I think the codes can be present without a "check engine" light. Take it to a tranny shop, and they should pull em for free.
I just ordered the adapter cable, should be here in two days, and I just downloaded a nice program. I'll be able to hook up this weekend and see what it's saying.
In the meantime, I'm hoping someone will recognize these issues and be able to shed some light on the subject.
how does the fluid look?light pink still good.dark pink or red and stinky = bad and burnt.bad fluid can cause a lot of problems.if something is wearing out quick,pieces can get stuck in the valve body and cause it not to shift properly.what you have going on sounds like every tranny i have had go bad on me.it wont be long til you start losing gears.usually o.d. first to go.
i also found this on a quick search on web site http://www.gmtruckhq.com/?q=node/93
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST. This guide is meant for problems that do not show up as PCM codes (like shift A&B solenoid failures, for example).
NOTE:The transmission is on the same fuse as the MAF, O2 sensors and at least one other sensor - if an O2 shorts out, it will blow the fuse and the trans will go into limp-home mode. Be sure the trans has power and the fuse is not blown before doing anything else.
Also note that many problems that show up as transmission issues are actually PCM or electrical, and may be external to the transmission. Try a different PCM, and check for chafing where the cables come out of the PCM.
Secondly, put a line pressure gauge ($55 shipped on Ebay, or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.500" boost valve (easy fix in pan).
Beware of coolant contamination - coolant will cause clutch packs to delaminate and thus cost you a rebuild! Trans fluid eats radiator hoses! If you find any sign of cross contamination, fix the problem and thoroughly flush both systems IMMEDIATELY.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
R&R = Remove & Repair (or Rebuild) = Transmission must be removed to fix the problem and may have to be rebuilt or replaced.
Common failures on 4L60E, symptom < cause > any possible repair:
1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace.
5. Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off. R&R. Try not to run or drive the car or further damage could result.
9. No 2nd or 4th gear. 2-4 band is slipping. Servo seals may be damaged (can be fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
10. Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
12. Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
13. No TCC lockup: Brake pedal switches improperly adjusted (always on), TCC solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace TC).
14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are applying due to a cracked or leaking forward piston. Overrun clutches will be worn out after 30 seconds of this behavior. Car can be safely driven in D. R&R.
16. Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products (Firestone stocks it).
17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.
19. Loud bang, grinding sound, loss of all gears, and a binding driveshaft: snapped output shaft. Try to wiggle driveshaft - if more than 0.020" play, that's the sign. R&R.
20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
22. Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
23. 3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
24. Fluid leak out of the front of trans where the converter connects; partial or full loss of movement: Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
25. Torque converter shudder in 4th while lockup is engaged; problem goes away when the brake pedal is pressed slightly to unlock converter. Have a shop verify line pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a transmission flush by a shop that uses BG brand products.
26. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
27. All fluid pumped out through the vent tube: Plugged cooler line. Flush the transmission cooler and cooler lines. Also could be overfiled transmission.
28. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels loaded in P, all four forward positions work fine: R&R: Internal crossleak feeding the forward clutches all the time. Most likely a cracked input housing, or cracked forward piston means forward clutches are fused together. Car can safely be driven gently in forward gears until the repair.
29. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
30. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
WOW!!!! Good read! I'll have to sit down and soak all that in tonight.
Seen those symptoms a hundred times with a 4l60e. The 3-4 clutch is toast, the computer commands a shift but when it doesn't see the shift (because if the slipping clutch) it goes into limp mode or the stuck in second gear you've become accustomed to. When you turn the key off you reset the computer and it tries again, if you're more or less coasting then it can make the shift because there isn't enough torque to make the 3-4 clutch slip.
Hate to say it but it's time for a rebuild.
