My Blazer won't start, it's cranking fine, doesn't sound like it's firing...I read old posts and someone with the same symptoms referred to an ESC module? What is this? and where is it located on an 85 K5????
Huh? Anyway, it's got to have gas, fire, and air to run. See if you can find any of those missing and then work from there. Maybe that was a typo er something. I hope someone else can come along and shed some light on this for ya!
Check to see if the carb is getting gas. Take off the air cleaner, and pump the gas...do you see it shooting into the primaries? If so, you've got teh fuel aspect taken care of. From there, just take off a plug wire, have someone crank it, and check for spark...i'm betting no spark if you are getting fuel and its not trying to fire.
Dorian
My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
What yr blazer? If its HEI remove a spark boot, insert a screwdriver, ground (small air gap, like a sparkplug gap) the screwdriver on the block,frame...... and have some crank the engine. You should see a spark, if not, you need to replace the module. They're about 30 bucks at most parts stores.
"My blazer may be slow, but it goes faster at higher speeds"
No spark, nothing......You guess the module then? nothing to do with the distributor?
Why would this be the case, it was driving normal last night, just wouldn't start this morning.
The module is inside of your dist. You remove the cap and underneath the vac advance pot there is a "horseshoe" looking device, that is your module. To remove it the vac adv plunger arm has to come off. I think its a c clip that hold it in place. Then remove the two 5/16th screws and the module will pop out. Most places can test these. Be sure to put the silicone underneath the new one before you install it. These give out when they have nothing better do to. I have had them crap out in the middle of rush hour. GOOD LUCK
Hey what part of Alaska are you in? I have some friends in Palmer
Man I'm never gonna reply to a post for you again! My module burned up tonight! No [censored]! I help you and what thanks do I get? Alright, I see how it is...........My fault tho'
Hey if you can get your hands on a Palmer phonebook I'd like you to look up a few names if you could/would.
Agh, raining tonight, and of course the garage is still full of winter crap....I'll have to take out the module tomorrow in the driveway, I went out and bought a repair manual so I know what I'm doing hahaha,
Sure, gimme names and I'll do what I can for you...
