what's crazy is that they are charging more for plain gasoline like it's some kind of special formula when the stupid ethanol is the added thing...go figure...before Obama regular gas was around $2.00 a gallon with no ethanol
Only a couple of places around here that have it and they are CFN stations. I'm not even sure how those work outside of commercial accounts and if I am able to use them with a personal bank card or not.
I would like to try a tank or so to see if there is any difference. From things I am reading, it does seem to help with better running and slightly better fuel mileage.
Thats due to the corn subsidies they pay farmers to grow corn for the ethanol I'm told--it ends up costing more to make less efficient fuel,that ruins things!..typical government intervention...we should be eating the corn,not wasting it to make ethanol!..it drives up food prices too...
As we have all seen on the EFI trucks covered by CK5 website... what rubber line splits? The only one left in the tank!In the EFI vehicles the rubber fuel lines split, but I expect that is partially a result of the ethanol weakening the hose PLUS the pressure the hose is subjected to. On a carbed setup that one doesn't wish to have fires, the pressurized portion of the line is steel and thus not an issue. May still cause issues with other sections of rubber line, but with little/no pressure, it would drip fuel at worst.
That's some really good fuel! Higher octane and as long as it is stored properly it will last forever!Is there an airport near you...looks like they all sell ethanol free fuel but they don't advertise ...probably fuel for small aircraft
Depending on vehicle and year? You will! Storage of vehicle or lawn equiptment is the worst part of this E fuel.I run ethanol in everything and have no problems.
Martin
In newer computer controlled vehicles you will see a performance and MPG gain just by running non E fuel or higher octane because the PCM has two timing tables, low octane and high octane. The PCM is always adding spark and looking for knock and adjusts the spark advance to as high as possible. I always run the high octane and because of it I never have knock counts. Who wants to force their motor to knock all the time? Albeit a small quick amount of knock for PCM testing purposes.I would like to try a tank or so to see if there is any difference. From things I am reading, it does seem to help with better running and slightly better fuel mileage.
So it's safe to say that vehicle manufactures were getting ready for this, but not quite done by 1991? When did the ethanol fuel start and when was it mandatory? Curious...
We've ran ethanol in the old man's 1976 C65 since the early 90's. It sits for months at a time. We also run it in his 1950's IH Super M-T/A. He has ran it in every lawn mower he has owned since then, as do I.
Martin
also...If you want to know who has the really cool old muscle cars in town, just wait around at a gas station that has a pure gasoline pump....I saw a sweet 1953 Corvette pull up and fuel up the day I was checking prices.
Most people with souped up cars are switching to E85. The hot rod guys LOVE ethanol.
Martin
Martin
But restored classics the guys want regular gas
