https://www.chevrolet.com/sema
They're showing their new crate connect & cruise battery/motor system to retrofit aftermarket vehicles. They happened to use a '77 K5 as a test platform.
From all the articles I've dug, there is no mention of heating or A/C modules, so i guess you don't drive this in the winter, rain or extreme heat. Owning a Chevy Volt, heating is a big deal and really robs the car of range almost as much as driving does. However, I do really like the Volts electric a/c compressor pump, alot more compact and efficient than an engine driven one. The A/C pump would be easy to retrofit here. Heating is usually accomplished, in the Volt and Bolt anyway, via a separate coolant loop heated electrically (or by the ICE in the Volt)
GMPP has tentatively slated the Electric Connect and Cruise system for sale to authorized installers (read trained by GM) in late 2021.
GM said:Powered by a Chevrolet Performance Electric Connect and Cruise system, the K5 Blazer-E is an all-electric conversion of an iconic SUV. Starting with a stock 1977 K5 Blazer, the K5 Blazer-E replaces the original engine, transmission, exhaust and fuel system with a 4-speed automatic transmission paired with a Bolt EV electric motor offering 200 horsepower and 266 lb.-ft. of torque – all while leaving the rest of the drivetrain fully intact.
autoweek said:Power for the Blazer-E comes from a 400-volt Bolt EV battery pack with 60kWh of usable energy installed in the cargo area. The output is about 200 hp and 266 lb-ft of torque, more than the stock ’77 Blazer’s 175 hp from a 400 cubic-inch gasoline V8. So it’s ahead of the game already. Torque is routed through a Chevrolet Performance electronically controlled four-speed automatic and thence to the remaining stock ’77 Blazer transfer case, driveshaft, differential and axles.
New parts include an electric power steering kit, an electric pump to send vacuum pressure to the stock brake system, and an electric controller to drive inputs to the vintage Blazer gauges now showing battery state of charge where the fuel gauge used to be, for instance.
