Hi guys,
I think something may be going on with my fuel system. In particular, I think it may be an issue with my EVAP system.
Here is what happened this morning...
Instead, it seems that the gas pump is shutting off prematurely, which has to mean something is wrong with my EVAP system? Do these trucks have a common point of failure that you all have seen a million times already?
- Fuel gauge was at 1/4 tank full.
- I went to the station and pumped gas until the hose shut off. The pump showed that I pumped 10.X gallons (can't remember the exact number).
- I thought that was a bit low, so I started pumping gas again. The hose shut off again at 11.4 gallons.
- I got back into my truck and started it up. The fuel gauge went up to 3/4 tank full.
- I drove off and went to work. Shortly after pulling out of the station the fuel gauge settled just above 1/2 tank full. It stayed there for the whole drive.
