TheBeast_88K5
Banned
I did... Today.... It was a simple balljoint replacement... On a Cherokee.
It seriously took me the better part of 4 hours to do ONE SIDE.
(Almost) EVERYTHING WENT WRONG!
Jacked it up
pulled the tire
removed the caliper, zip-tied it up.
Pulled the rotor...this is where the ease CEASED.
Removed the 3 bolts, that hold the hub to the the knuckle.
The Hub flange-thingy WOULD NOT BUDGE.
I convinced the sh*t out of it with a hammer and screwdriver.
Then just a BFH, after about 20 minutes, it just let go.
Then the knuckle took 20 minutes of convincing.
Then each gawdamn balljoint was practically WELDED to its bore.
Then the upper replacement joint had a minute manufacture defect....
It cascaded outward in thickness, like a cone.
Not noticable to the naked eye, but just f*cked up enough to get half way in and STOP.
The second upper balljoint went in NO TROUBLE AT ALL.
Just like it should.
I should also mention that the tolerances were so tight,
That my impact wouldn't work, for the press, so I was doing the installing by hand.
2' breaker bar, and 2' cheater-pipe, on occasion.
The lower replacement was another gawdamn story.
It went 3/4 of the way in, then stopped.
Of course the knuckle was too small to get the bj press in there correctly.
Had to jimmy-rig my own adapter for it... Bastard HEEP.
Once it was all the way in, I noticed the threads, near the base, were shrugged.
Prolly out of the box, I never checked, but didn't do anything that would have caused it.
So, I had to do some slick, impact usage, type stuff.
Basically chased the threads, trail style.
Fast forward to everything back on,
I'm tightening the caliper bolt.... Then, SNAP!
First bolt I ever broke in my life.
Seriously... With 35 ft lbs of force...wtf?
Had to wait 20 more minutes for the guy to get the new bolts.
Which went in like a charm.
Took me 3 1/2 hours to replace 2 freaking balljoints.
I'm freaking BEAT, I have a smashed knuckle, and a b*tchen headache.
Gawdamm jeeps.
Never again.
Edit: spec is 30ft lbs... NOT 77ft lbs., edited for correction.
Jacked it up
pulled the tire
Gawdamm jeeps.
Never again.
