Everything for a TUNE UP???
anatomiczero
Washington
The engine hasn't had a tune up, well ever. It was put in 6 years ago. So what's everything I should change? Cap & rotor, wires, plugs, re oil K&N filter. Well the only thing i've done to it was change the fuel filter.
im not sure if you have an o2 sensor but if you do, change it. if your running an automatic tranny and youve never changed the fluid i would not do it now the fresh fluid will eat up the clutch packs i would also change the fuel filter again if its been a while plus all of the other things you mentioned plus maybe some fresh gear oil in the axles lube up all of you zirc fittings plus some fresh fluid for your transfer case and check over your belts and hoses hope this helps /forums/images/graemlins/thumb.gif
Cap, rotor, plugs, oxygen sensor, clean and re oil the filter, oil change, oil filter, trans filter and new trans fluid, change front/rear diff oil and t-case oil, pcv valve, and run a bottle of GM combustion chamber cleaner thru her (before the oil change and oxygen sensor change) this works wonders, and then consider adding a fuel system additive/cleaner (this should give you 40 or 50 km more on a tank of fuel)
What's involved with that combustion chamber cleaner? Does it smoke a lot, what should I expect? thanks.
yeah it will smoke just go to the dealership and get some top cylinder cleaner i belive thats what its called and find a vacume hose to your intake thats not big enough to kill the engine and stick it in the bottle then start her up and sit there watching it because it will try to kill the engine just like carb cleaner so you have to take the vac line out from time to time run the whole bottle through and dont bother about the smoke
