chrisb420
Well guys, sad to say it but i am done with 4 wheeling, The truck body was taken off and scrapped and everything else needs to go. This is the list, There may be more but haven't found it yet.
86K5 frame.
custom made frame crossmember (see 3rd set of pics)
350 engine, ran 4 years ago but rebuild couldn't hurt.
Custom made rear bumper with brake and back up lights and spare holder for 8 lug
GM reman 700r4 with less than 100 miles includes torque converter.
2nd 700r4 trans that needs rebuild, no forward gears.
2 NP208 transfer cases.
set of 4 15x8 aluminum rims and roller tires. 6 lug
5 16.5 x 9.75 Mickey thompson classic 2 wheels, 8 lug
5 36x12.50x16.5 goodyear humvee bias ply tires, 1 has dryrot and would be a spare the other 4 are 80-95%
14 bolt rear, unassembled, has all parts including brand new install kit and brand new 4.88 motive gears, never installed.
3/4 ton 10 bolt front, 8 lug ,gears unknown, spins freely.
DIY4x shackle flips,
DIY4x 14 bolt disc brake conversion, rear rotors, calipers, and brake lines.
DIY4X u bolt plates and never tightened u bolts for 14 bolt.
14 bolt rock ring.
Pro comp 2.5'' front lift springs.
4 pro comp es3000 shocks
Couple of front drive shafts.
Couple of rear driveshafts
steering arm for lift kit, installed on axle with new hardware.
2 sets of body lifts, 1 aluminum spacers, 1 polymer spacers.
1 set of poly body mounts
passenger side aftermarket fender and inner fender, no rust.
aftermarket tailgate shell, installed for a month never assembled, no rust.
aftermarket rear tailpan no rust.
right side tailgate support replacement panel.
all tailgate parts i have including latches, glass, hinges.
all salvagable body stuff like hood and door hinges, hood springs. everything i could salvage.
1 good steering column, 1 bad column
several sets of window glass
brake booster
2 different dash bezels
New aftermarket front grille and headlight bezels painted black.
all new headlight buckets and hardware.
all bolts and hardware i salvaged while scrapping the body
there is alot more stuff but I will be here all day typing. basically you can have everything i have collected over the last 4 years for $1000. I just don't have the time or money to go forward with this and want to get rid of everything in one shot.
Take a look at my sig for a link to webshots pictures. More pics coming.
Anybody interested pm me here or email at [email protected].
86K5 frame.
14 bolt rock ring.
brake booster
