I have this issue on my '89 Pontiac 6000 w/3.1L.
Not running, cold, 12.5v normal...start it up and it has 13.9v or so for a few mins. After a few mins, voltage drops to 12.5 or so and keeps falling slowly to around the 11.7 mark after 15mins or so. Worse, you can hear the load kinda kick in on the engine when it happens, like you just hooked up another dead battery for jumping or something.
If you rev the engine it comes up a bit, but no where near 14 where it should be. If you drive it it won't lose the battle most of the time, but won't be 14 either. COming to lights is nervous as sometimes it'll drop to 11 and the engine starts to get a bit rough probably because the voltage is dropping to a point where the fuel pump can't keep up. Yes, the problem seems worse at idle in gear but I think that's just because rpm is a bit less sitting in gear than in park. Also worse at night with the lights on.
I've checked positive cable connections, negative main cables and a few grounds elsewhere including engine ground strap. I also checked the main alt. feed cable and cleaned them all up.
I've changed the battery for a brand new one thinking mabey the battery had a dead cell. After that didn't change the behavior at all, I changed the alternator even though three different places tested the old one as just fine. Also, didn't help. I've tried jiggling various wire harness's, cables, near the starter, battery, alternator and many other places, no amount of jiggling changes the voltage.
Nothing seems to fix it. It doesn't appear anyone's messed with anything previous, there's no additional electrical accessories, no add on amps/stereos/lights/winches (it is an AWD car, mabey it needs a winch!)
There seems to be some kinda of load constantly somewhere but only if it's running and not dead cold.
I'm rather puzzled on this one and don't know where to look next. Any suggestions??
