Excessive oil from vlv cvr breather bbc
Frankenblazer
Registered Member
Richmond
I have excessive oil comming out my valve cover breathers on my bbc ,they are open element breathers on edelbrock signiture series, doesn't blow smoke out tail pipes or burn it.
Probably right ,kind of simple, I should of thought of that.although a lot of oil comming out,any recommendations for pcv number or brand?
ACDelco CV774C GM Original Equipment Positive Crank Ventilation
probably could use a baffle inside the valve covers. the rocker under the hole might be spraying oil right into breather. as well as pcv system
It does have a baffle inside valve covers ,I thought I be good running 2 breathers , but apparently not since it dumps out about 1qt every 100 miles
I had some Chevy performance valve covers that did not have baffles, they’d pour oil out of open element breathers.
My valve covers have the baffles, but I should've known to install a pcv system of some sorts
No baffle trick in video. if you have baffle PCV. In the beginning he addresses the “two breathers” being no bueno
