While I was replacing a caliper on my Dana 60 I noticed that the hub/disk assembly had a lot of lateral runout in it (like 1/16" side to side movement of the caliper every rotation). So I figured that the wheel bearings just needed to be snugged up. Pull it apart, find everything normal, reassemble to specs, same problem.
Break out the dial indicator and measure it. 0.023 runout measured on the disk. 0.012 runout measured on the hub. No significant play in the bearings (0.001-2) Ok, my wheel bearings must be bad or the races arnt seated or something. Pull it all apart again, everything looks fine, beat the races in anyway. Reassemble, same runout. Pull it apart, pull out the races. Clean the hub out, reinstall the old races. Reassemble, same runout. Ok... now im annoyed. Pull it apart, install new bearings, new races, new seal. Same runout.
On like the 3rd reassembly I noticed that the bearings didnt just slip onto the spindle like I expected, had to be at a certain "clock" position to go on. This was with the old bearings (Timkin) and the new (National). The old bearings have like 100 road miles on them, 0 miles offroad.
Any idea what to do next? Is my spindle or hub bad? What is acceptable lateral motion on the Dana 60 caliper?
Also: This vehicle wont be on public roads anytime soon.
