exhaust and trac bar mouting
MNorby
3/4 ton status
Powell, Wy
need to loose my turbo mufflers for some room, hate the sound the glass packs crackle. anything that doesn't do that?
Magnaflow makes some inline mufflers, Im not sure if they cackle or not, I have a Magnaflow on my SBlazer but its a offset OEM Style.
i can't think of ****.i remember the header mufflers i had on my impala. they sounded great. but header mufflers sorta don't work with t cases.can you run strait pipe? 2 1/2 inch really isn't that loud with normal driving.
Flowmaster has the new hushmaster, cant say how it sounds though, didnt see a soundclip on their site.
prob is I am building a trac bar and need room, I only have 1" clearance from driveshaft to muffler as it is and its tight to the frame. I am starting to lean toward trying to fit a crossover pipe under the rear output on the 205 and going to a single 3 out. Prob is there not much room but doable but also I want to do a high angle driveline parking brake off my rear output someday and don't wanna kill that clearance too.
I too am looking for a new muffler to run. Right now I have a magnaflow that's about 2 feet long. I heard that the longer the muffler is, the quieter it is.
I want some loud grumbly exhaust, almost like open headers just toned down a bit.
i want as quite as possible, nothign worse than on a trail and can't talk to person next to you. bad enough with no top/doors
i am in the same boat as you.. i have my traction bar and had to build up a horrible ghetto exhaust... pisses me off to no end! anyone wanna give pictures of their exhaust with traction bar?
Its not as close to the exhaust as it looks :D
can't move mufflers back and don't want to run straight pipes.
