Drove the K5 today for several hours with the rear window down. I have side pipes that exit behind the rear tires. I need to do something about the exhaust fumes in the K5. Anyone else have this problem?
The tail pipe is under the cab. This is some really good information you share as I'm about to replace the exhaust pipes and muffler. I'm running a dual pipe setup currently.Can you post picture of your tail pipes? I have mine out at about 60* behind the rear tires and i dont have fumes. The key is making sure the tips extend out fron underneath the truck. If you have any portion of the tailpipe that is under the cab it will get sucked back in. If it extends past the side of the cab it wont get sucked back in.
Couple different angles of mine. Bolt on Tips are nice so you can adjust as needed
Fyi, I’m TBI, true duals, no cat
This is how I have mine piped now. I have a soft top and no more fumesCan you post picture of your tail pipes? I have mine out at about 60* behind the rear tires and i dont have fumes. The key is making sure the tips extend out fron underneath the truck. If you have any portion of the tailpipe that is under the cab it will get sucked back in. If it extends past the side of the cab it wont get sucked back in.
