ryancross
Newbie
Hello,
I am wanting to perform an exhaust upgrade on my 95 K1500 Z71 with a 350 TBI. It has a 4L60 E and 3.42 gears. The tires are 30.7 inches tall. I need to run a cat where I am. My friend has done the following on an identical truck and has seen a 1.5mpg improvement in fuel economy in the city and has a good bit more power. He ran all new 2 1/4 pipes from the factory manifolds to flowmaster Y collector with 2.5 inlets and a 3 inch outlet. This runs straight into a 3 inch cat. A 3 inch pipe then runs from the cat to a Hooker Aerochamber single inlet dual outlet muffler. Inlet is 2.5 and outlets are 2.5 as well. He then has two separate 2 1/4 pipes each of which come off one outlet on the muffler and exit behind the rear wheels.
Does anyone think I could improve on this combo? For instance decreasing or increasing any of the diameters of the pipes, y collectors, cat and muffler. Any and all suggestions or discouragement are welcomed. Thank you for your time.
Ryan
Ryan
