JBerno
Is there anywhere to get an exhaust system for our 72 blazers? I am thinking about buying a small 90 amp flux wire welder from HF and welding it up myself.
Ideas, thoughts?
Ideas, thoughts?
Ideas, thoughts?
If i bought a 2.5" die for a jd2 bender.... Could i bend exhaust tubing with nice mandral bends? Or would that not work?
. You an buy an exhaust "builders kit" from Summit or Jegs that has all sorts of pre-bent segments is what ever diameter you need. You can cut and weld those into a perfect-fitting system.
