I've just bolted the exhaust manifolds on with NO gaskets--provided they aren't warped to hell,you dont need any--GM never put any there that I know of,I removed dozens of manifolds at the junkyard and never saw any with gaskets that hadn't been added after the vehicle was sold.....................I use anti-seize,but its more important to put a lot on the shanks of the bolts than the threads--the bolts always tend to seize where they pass thru the holes in the manifolds,not so much in the threads in the cylinder heads,and the heads will snap off them when you go to remove them...........................................................................................................................................................................................................We often had to use a torch to blow off the bolt heads and use a bar to pry the manifolds away from the head when removing an exhaust manifold off an old engine--many times the bolt heads were so rotted no wrench could grab them,and vise grips could not be used,the frame was in the way..so once we got the manifold away from the head as much as possible,we'd cut the shank off the bolts as close to the manifold ,then it was pretty wasy to remove the remains with vise grips...................................................................................................My friend replaces a lot of exhaust manifolds on later Ford trucks--yesterday he was doing a pair on a '99 Expadition,and they were so rotted he had to use bolt-out extractors on the few bolts that had any heads left on them,and then sawsall-ed the manifolds off --its amazing,that a sawsall will slice thru a cast iron manifold (and the bolts) like butter much easier than you'd think,its becoming his favorite way to get old ones off quickly without damaging other parts or having to use a torch...usually they are less than 1/8" thick by the time they start cracking and leaking....he uses no gaskets,after making sure the new or good used manifolds are flat.....he has done maybe 50 pairs this way the past year--his best "customer" in Meinekie,they refuse to work on anyones exhaust manifolds if they need replacing,or even just the studs!...and they call themselves an "exhaust shop"????.....
