Exhaust Placement In Relation To Fuel Tank
Resurrection_Joe
1 ton status
Gettysburg, SD
I was donking around Pirate and I happened upon a post about moving gas tanks on Toys. Seems that someone had problems with the exhaust vapor locking (vapo rubbing, vader darthing) and whatnot the motor from exhaust heat.
My mufflers are going to be running 2"-3" below my gas tank, should I be worried about that? The rest of the mufflers are open to air.
Anywhooooooo
Oh and if it is too hot, can I run some sort of heat shield?
There's the muffler, they're snugged up to the frame, the tank iwll be sitting on 2" stock and some rubber strips.
The gas tank should be fine, just run some heat shields. I picked some nice aluminum ones up from Summit that were made to fit my Flowmasters. Usually vapor lock happens in fuel lines or the carb, I've never heard of the tank getting vapor lock, there's too much fuel in there to get all of it that hot.
You're welcome.
Just smear some extra heavy duty mayonnaise on the bottom of the tank, it'll work like a champ. /forums/images/graemlins/thumb.gif
*Theoretically*, if you raise the temperature of the fuel in the tank, you also raise the temperature of the fuel traveling in the lines.
Once it gets to the engine bay though, that more-warm-than-in-a-stock-setup fuel might become TOO hot, and *then* you'd have a problem with vapor lock. Since the pickup is at the bottom of the tank, possiblity of vapor affecting it right there is pretty slim. You'd have to be boiling the gas to make it a problem. (Only seen that in a lawn mower lol)
I doubt it's likely to cause any problems, but the fuel tank does a pretty good job of supplying "cool" fuel to the engine.
