exhaust question
slackjawsk5
berlin,wisconsin
hey guys i was wondering what would cause whitish grey exhaust to pour out only on of my tail pipes. the engine sounds good, thought it could be a head gasket or something what do you guys think
is it after the truck warms up or when its cold, your question is very short and not a whole lot of info.
im guessing all the time but i say a leaky intake or head could be the culprit. i had a intake gasket go on a 305 and it poarded white til i change them....
LUKE
just a thought
Yep... sounds like steam.
Head gasket, cracked head or cracked cylinder wall.
which tail pipe, and what trans are you running?
if a trans with a vac. modulator(350/400) and the vac line is to a runner on one side or the other(I have seen most to the runner for #8 cylinder, pass side) , and the modulator is bad, it will suck trans fluid into the runner
p.s., trans fluid burns white
If it is grey, it could be running too rich. A rich mixture cuases grey smoke. coolant causes white smoke. try the smell test on your exhaust. If it has a sweet smell it is coolant. If it is gasoline, then it will have a chemical type of smell.
Last I checked, too rich caused black smoke
Black smoke is normaly a sign of burning oil.
Black smoke = oil
White smoke = water
Grey smoke = gas
But this is not written in stone or anything.
Black smoke = oil
White smoke = water
Grey smoke = gas
I think you got your gas and oil backerds. Oil definitely produces whitish/blueish smoke. I get reminded of this every time I start my Blazer. :D
I suppose grey could be taken for blue so it could be an oil burning issue. And if there's that much oil burning, then the transmission vacuum line is definitely a good place to start looking.
Just to coroborate: http://www.bellaonline.com/ArticlesP/art10101.asp
