Hi all im new here and im glad to be here.
I have a 1990 K5 scottsdale and i cannot find out why my exhaust smells strongly of fuel. I have replaced the injectors, serviced the TBI with a throttle body spacer, replaced the regulator spring and diaphragm and all gaskets. The injectors seems to spraying fine. I have checked the usual's in my haynes manual emissions section. the EGR valve is moving with slight pressure as it should and the PCV valve seems to be working, In the book it says there should be vacuum but it seems to be blowing air instead if thats okay???. Im new to the city im in and i do not know the community i used to.
It also idles a bit low at first start up when cold and then picks up and few times and works itself out. im assuming this could be a part of the issue. Any information would be awesome if anyone has had this issue before.
Thanks again
1990 k5 350 sm465trans 240k km
Thanks again
