Ok guys so here goes....
84 GMC K2500, bone stock 350 4V w/700R4.
I currently have a bone stock exhaust system. Air tubes (no air pump), heat riser (actually works!) you name it.
I would like to try and free up the exhaust flow some. Trying to stay away from Headers as a decent set cost $$$. Figure the cheap sets rot out/leak and I'm a little old for that.
So I take note it looks like the Y pipe has a 3" outlet on my 91K5. I could deal with a single 3" exhaust. Problem however is I'm thinking no way will that Y pipe for a K5 fit my K2500, especially with the heat riser. Little more looking around shows the 87 TBI trucks also used a 3" Y pipe.
Best guess is to run the TBI 3" Y pipe I need to run the TBI exhaust manafolds? (plug the O2 bung).
Any ideas?? Just trying to get a decent exhaust on the cheap.
