I prefer rubber brake hoses over braded steel hoses. The last time I needed a pair, I took them to a local hose shop and had them make some for me. I was relatively expensive. Now, after doing the D60 swap, I needed some new hoses again. I went to NAPA to get some new ones to take and have extended. But the counterman suggested we look in the book to see if we could find a hose with the same fittings with longer rubber hose. After about fifteen minutes we came across the perfect hose. It is for a '98 Dodge 4x4, left side, and is about 14 inches longer than the stock Chevy hose. The pair only set me back $38.00. It has some metal brackets on it which will have to be removed and then will fit great. It also has a couple rubber sleeves on it which will be great to protect the hose when I tie it to the shock. I think the part # is 380295; I will confirm the # when I get home tonight. Oh yah, the new hose comes with a new banjo bolt also (although I don't know yet if it is the right thread). I will post more pics after I install the hoses.
